6 Replies Latest reply on Dec 30, 2014 11:50 PM by Deepak Gupta
    Simple API Help
    Greg Raymond
      Hello I am using a Macro currently that does a bounding box feature, I got this from a user here. I am looking to add a little more to it now, however I don't know how API works. I am somewhat experienced with C and C++ language, and can kind of sort understand the program language, however getting info out of SolidWorks, I don't know what's the protocol.
      What I am trying to accomplish is to add a new property that is dependent on the material. So I just need about 6 If's statements. Kinda copying and pasting what I have in the macro, this is what I am trying to achieve.
      retval = Part.AddCustomInfo3(ConfigName, "Treatment", swCustomInfoText)                                   // Adds a new property called "Treatment" in the Properties > Configuration Specific
      If getPartMaterial = "A2" Then        // Check for the part material (I don't know what function to use here)
        retval = Part.AddCustomInfo3(ConfigName, "Treatment", swCustomInfoText, "R/C 56 MIN")          // If the material is A2, then it will fill the text with "R/C 56 MIN"
      End if
      That's what I am basically trying to achieve, I just need some fine tuning because API is not familiar to me. Thanks.
        • Re: Simple API Help
          Greg Raymond
          Playing around with it more I got some of it down. I just need to retrieve the Material property off the part file.
          retval = Part.DeleteCustomInfo2(ConfigName, "Treatment")
          If (Need help here!!!)
              Deepak Gupta
              Try adding/using these codes:
              Dim sMatName                    As String
              Dim sMatDB                      As String
              Dim swPart                      As SldWorks.PartDoc
              Set swPart = swModel
              sMatName = swPart.GetMaterialPropertyName2("Default", sMatDB)
                  If sMatName = "A2" Then
                  swModel.CustomInfo2(Configuration, "Treatment") = "R/C 56 MIN"
              Though custominfo2  is an obsolete property but works. Using custominfo2 you can change the value of the existing property instead of deleting it and re-adding it.
                  Greg Raymond
                  Thanks! That works like a charm. Now is there any way to add the "Treatment" property in there? It's in the template of the part but just in case someone deletes it or we take an old part with an old template.
                    Deepak Gupta
                    It would be better to assign a new variable say Value
                    Dim Value                          As string
                        Select Case sMatName
                              Case "A2"
                                  Value = "R/C 56 MIN"
                              Case add other checks here
                                  actions for other cases here
                            Case Else
                                    use only if an action is required when no match is found
                        End Select
                        If swModel.CustomInfo2(Configuration, "Treatment") = "" Then
                            retval = swModel.AddCustomInfo3(Configuration, "Treatment", swCustomInfoText, Value)
                          Else
                            swModel.CustomInfo2(Configuration, "Treatment") = Value
                  Matt Martens
                  In your original post you mentioned having 6 if statements. Instead of having 6 ifs, use a select case statement.
                  Expanding on Deepak's code it would look like this
                            Case "A2"
                          Case Else
                       End Select
                  You can have as many cases as you like. Just keep adding them in.
