How to get mate name for select/delete
Question asked by Drew Miller on Dec 30, 2014
Latest reply on Dec 30, 2014 by Drew Miller
Using 2014 and VBA with an open assembly.
I am looking through mates and finding mates that are of inplace type and have a certain matecomponentname.
Once the correct conditions are met then I would like to be able to select and delete the mate.  If I know the name of the mate then
it can be selected using selectbyid2.  Problem is I can't seem to get to the mate's name (for example "InPlace1").. there must be an easier way to get the right mate and delete it?
        Components = swAssy.GetComponents(False)
        For Each SingleComponent In Components
            Set thisComponent = SingleComponent
            Debug.Print "Name of component: " & thisComponent.Name2
            Mates = thisComponent.GetMates()
            If (Not IsEmpty(Mates)) Then
                For Each SingleMate In Mates
                    If TypeOf SingleMate Is SldWorks.Mate2 Then
                        Set swMate = SingleMate
                        typeOfMate = swMate.Type
                        Select Case typeOfMate
                            Case 0
                                Debug.Print "  Mate type: Coincident"
                            Case 1
                                Debug.Print "  Mate type: Concentric"
                            Case 2
                                Debug.Print "  Mate type: Perpendicular"
                            Case 3
                                Debug.Print "  Mate type: Parallel"
                            Case 4
                                Debug.Print "  Mate type: Tangent"
                            Case 5
                                Debug.Print "  Mate type: Distance"
                            Case 6
                                Debug.Print "  Mate type: Angle"
                            Case 7
                                Debug.Print "  Mate type: Unknown"
                            Case 8
                                Debug.Print "  Mate type: Symmetric"
                            Case 9
                                Debug.Print "  Mate type: CAM follower"
                            Case 10
                                Debug.Print "  Mate type: Gear"
                            Case 11
                                Debug.Print "  Mate type: Width"
                            Case 12
                                Debug.Print "  Mate type: Lock to sketch"
                            Case 13
                                Debug.Print "  Mate type: Rack pinion"
                            Case 14
                                Debug.Print "  Mate type: Max mates"
                            Case 15
                                Debug.Print "  Mate type: Path"
                            Case 16
                                Debug.Print "  Mate type: Lock"
                            Case 17
                                Debug.Print "  Mate type: Screw"
                            Case 18
                                Debug.Print "  Mate type: Linear coupler"
                            Case 19
                                Debug.Print "  Mate type: Universal joint"
                            Case 20
                                Debug.Print "  Mate type: Coordinate"
                            Case 21
                                Debug.Print "  Mate type: Slot"
                            Case 22
                                Debug.Print "  Mate type: Hinge"
                            ' Add new mate types introduced after SolidWorks 2010 FCS here
                        End Select
                    If TypeOf SingleMate Is SldWorks.MateInPlace Then
                        Set swMateInPlace = SingleMate
                        numMateEntities = swMateInPlace.GetMateEntityCount
                        For i = 0 To numMateEntities - 1
                            Debug.Print "  Mate component name: " & swMateInPlace.MateComponentName(i)
                            Debug.Print "    Type of mate inplace: " & swMateInPlace.MateEntityType(i)
                        Next i
                        Debug.Print ""
                        'get mate name somehow
                        boolstatus = swModel.extension.SelectByID2(matename, "MATE", 0, 0, 0, False, 0, Nothing, 0)
                        swModel.EditDelete
                Next
            Debug.Print ""
        Next
