Hi you all...
I want to create a part, and add it into the toolbox. When i'll select my part from toolbox and click to create part,its dimensions must be changeable.
For example, i designed a rectangular prism to toolbox , and it has a dimensions such as "w","d" and "h".
After i clicked to create part, i could change the dimension of w, d and h.
How can i make a connection between the dimensions of my parts and toolbox ?
P.S: : I created my part with Configuration Publisher, and with it , i can do what i want, if i save my part as *.sldprt and insert it into assembly.
The view of my part in toolbox.
The view of my part created from toolbox. I can change the dimensions, but that doesnt affect the part..
The view of the Configuration Publisher options while i am configuring.
After i created the prism , and insert it to the assemby tample, and the dimension can be changeable. The view is bottom...
You can simply keep the part in the library from where can also drag drop into assembly. And this would work on machine having no toolbox too.
