PTPeter Thannhauser27/12/2014
Is there a way to import the hole 'specification' originally defined from the Part into the corresponding Drawing? Example: my part defined the holes as tap drill for M3x0.5 thread using hole wizard selections. In the drawing, I used Model Items feature to import the corresponding hole specs. It correctly shows the IPS equivalent drill size (0.098") and the dual dimension metric [2.50mm]. What I'm asking, is there a way to also display the 'M3x0.5mm' information?
