Is it possible to set an extrusion offset as an ordinate dimension so that it can be imported into the drawing as such?
Would you please rephrase your question? It isn't clear what you're asking.
I create a profile sketch on a datum plane, extrude in 1/2" and offset from the sketch plane 36"
I do this for several bodies. When I create my drawing I would like to import the offsets using ordinate dimensions as below.
Maybe this is clearer, Can I make the
offset a datum dimension.
