I have many parts that has 3 configurations: Casting, Soft and Finish. When making the sheet I have each configuration have its own sheet. When the shop needs a print usually they only need 1 sheet at a time. Sometimes each sheet is on a different size paper. "A" and "B" sizes we send to printer, "C" and "D" sizes we send to plotter.
Now the issue, When I select Print I select current sheet then Page Setup. In Page Setup I select Printer/Plotter and Size. When I hit OK for some reason it automatically resets itself to all sheets. If you do not catch this you are wasting paper lots of paper. Is there a way to setup EACH sheet to a particular printer/plotter and paper size and keep current sheet?
Have you tried to mark "Set each drawing sheet individually" in File -> page setup.
