5 Replies Latest reply on Sep 30, 2016 6:10 AM by Yong Ning
    IsSuppressed2→true and false
    Yong Ning
      2010 SolidWorks API Help - Is Feature Suppressed in Specified Configurations Example (VBA)
      http://help.solidworks.com/2010/english/api/sldworksapi/IS_Feature_Suppressed_in_Specified_Configurations_Example_VB.htm
      Private Sub del1419()
         Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
            Set SwApp = Application.SldWorks
            Set SwModel = SwApp.ActiveDoc
         Dim SwFeat As Feature
            Set SwFeat = SwModel.FeatureByName("Dn500")
            Debug.Print SwFeat.Name
         Dim ConfArr, vConfArr
            ConfArr = SwModel.GetConfigurationNames
            vConfArr = SwFeat.IsSuppressed2(3, ConfArr)
            Stop
      Private Sub ll()
        Dim Swapp As SldWorks.SldWorks, SwModel As ModelDoc2
          Set Swapp = Application.SldWorks
          Set SwModel = Swapp.ActiveDoc
          Set SwFeat = SwModel.FeatureByName("Dn400")
          vConfArr = SwFeat.IsSuppressed2(0, ConfArr)
          Stop
          vConfArr = SwFeat.IsSuppressed2(1, ConfArr)
          Stop
          vConfArr = SwFeat.IsSuppressed2(2, ConfArr)
          Stop
          Stop
        • Re: IsSuppressed2→true and false
          Daniel Andersson
          Hello Yong,
          I do not follow what you want to do. I noted in the first image that you point out you have configuration Dn500 active and that the feature Dn400 is not suppressed. I tried to open the attached SolidWorks files but they seems to be damaged some how.
          Are you looking for a macro that shows the suppression state for each configuration of the specified feature?
          If so, try this code. Please note that you have to change SwModel.FeatureByName to fit your needs.
          Private Sub main()
            Dim SwModel As SldWorks.ModelDoc2
            Dim SwFeat As SldWorks.Feature
            Dim vConfArr As Variant
            Dim vConfBool As Variant
              Set SwFeat = SwModel.FeatureByName("Chamfer1")
              Debug.Print "Feature: " & SwFeat.Name
              vConfArr = SwModel.GetConfigurationNames
              vConfBool = SwFeat.IsSuppressed2(swInConfigurationOpts_e.swSpecifyConfiguration, vConfArr)
              For i = 0 To UBound(vConfArr)
                  Debug.Print "Configuration: " & vConfArr(i) & "  Suppression: " & vConfBool(i)
              Next i
              Yong Ning
              Thank you Mr  Daniel Andersson,Thank you reply.
              Where your from Mr Daniel Andersson. Is English your first language?
              I am Chinese, First language is Chinese, can read English, but write english is very bad.
              Run this code → Set SwFeat = SwFeatMgr.InsertTableDrivenPattern(FileName, Nothing, True, True) → Need Suppressed Feature.
              Can use code is very slow. for ii = 0 to ubound(confArr) → need 10 min.
              Function EditSupp(SwModel As ModelDoc2, SwConfName)
                 Dim ConfArr, ii, jj, SwFeat As Feature
                    For ii = 0 To UBound(ConfArr)
                       SwModel.ShowConfiguration2 ConfArr(ii)
                       For jj = 0 To UBound(ConfArr)
                         Set SwFeat = SwModel.FeatureByName(ConfArr(jj))
                         If Not SwFeat Is Nothing Then
                            If SwFeat.Name = SwConfName Then
                              SwFeat.Select True
                              SwModel.EditUnsuppress2
                            Else
                               SwFeat.Select True
                            SwFeat.Select True
                       Next jj
                       SwModel.EditSuppress2
                       printTiming T
                    Next ii
                    SwModel.ShowConfiguration2 SwConfName
              End Function
              this sentence is very simple.
                SwFeat.SetSuppression2 swSuppressFeature, swAllConfiguration, vConfArr
              this sentence = Follow code,
              Private Sub main()
                  Set SwFeat = SwModel.FeatureByName("Hole")
                  Next i
                  Stop
                  Daniel Andersson
                  Hi Yong,
                  It looks like you have solved the issue and improved the speed with the your subs SetSuppSwSuppressFeature and unSuppSwSuppressFeature.
                  Going this way eliminates the usage of method IModelDoc2::ShowConfiguration2 which previously slowed down your code.
                  So I assume that you have solved your question. Just let me know otherwise.
                  My first language is Swedish, second is English.
                  (I once knew how to order a beer in Chinese, but that is since long time forgotten.)
                    Yong Ning
                    Private Sub del0930()
                       Dim SwSelMgr As SelectionMgr
                           Set SwSelMgr = SwModel.SelectionManager
                       Dim SwFeat As Feature, vConfArr
                           Set SwFeat = SwSelMgr.GetSelectedObject5(1)
                           'SwFeat.SetSuppression True
                           Next i
                           SwFeat.SetSuppression2 swComponentFullyResolved, swAllConfiguration, vConfArr
                           Stop
                           Stop
