I seems to be having some timeout issue with a PDMWConnection with PWM Workgroup. If create a SearchObject that has lots of results, it fails with a "Unknown Network Error (40)" but the same code works fine with a smaller subset.
I can get similar problems with the Solidworks Explorer. If select the same criteria that I did in my API call and tell it to generate a list, it tells me that there are no records found. However, if I limit the number of records to something like 3300 files, it works fine. This number varies depending on what i'm searching for so I don't think it is a hard number and leads to believe it is some timeout error.
Anyone know of a a way to increase the connection time out. Perhaps this is some setting on the server?
