5 Replies Latest reply on Dec 30, 2014 1:52 PM by Brandon Massoni
    Configuration Specific new Features
    Brandon Massoni
      I am cutting a part in such a way that it creates two bodies (parent conf). I need to store each of these bodies in their own configuration (children conf). How can I delete one body for each configuration?
      I tried the following three methods, but the parent and children configurations all have the same features with what I tried (both bodies deleted in all configurations). Code attached.
      1. swModel.ShowConfiguration2()
      2. swConf.Select (False) 'Selects only the current configuration
      3. swModel.FeatureManager.InsertDeleteBody.SetSuppression2 swSuppressFeature, swAllConfiguration, Empty
        • Re: Configuration Specific new Features
          Keith Rice
          Brandon,
          What you're trying to accomplish seems very similar to how I create left-hand and right-hand parts. I think the same methodology might apply. I actually have a free video that shows you how to accomplish this in a VBA macro. Check it out.
          Keith
          SolidWorks API Video Tutorials
              Brandon Massoni
              Keith,
              Not really. In your example, you never move between configurations, which is what I have trouble with. I can add the configurations and derived configurations easy enough (see code).
              Rather, I need an example of how to use "swConf.SuppressNewFeatures"  or another solution. The link at the bottom of this page EditConfiguration3 options may have been useful if it wasn't broken.
                  Keith Rice
                  What you're doing is similar because the problem is solved by having the correct configuration active when a feature is created or its suppression state modified. You don't need to get the "Suppress new features" option involved.
                  Your problem statement isn't clear as to whether you want one body suppressed or unsuppressed per configuration, but I am going to assume the latter.
                  'For each body in the part, create a configuration that contains only that body. _
                      All other bodies are suppressed.
                  'Precondition: part is open
                  'Written by Keith Rice
                  'CADSharp LLC
                  'www.cadsharp.com
                  Dim swFeat As SldWorks.Feature
                  Dim swConfig As SldWorks.Configuration
                  Dim vBodies As Variant
                  Dim i As Integer, j As Integer
                  Dim strOriginalConfigName As String
                  Dim colConfigName As New Collection
                  Dim colDeleteBodyName As New Collection
                      Set colConfigName = Nothing
                      Set colDeleteBodyName = Nothing
                      Set swModel = swApp.ActiveDoc
                      strOriginalConfigName = swModel.ConfigurationManager.ActiveConfiguration.Name
                      Set swPart = swModel
                      vBodies = swPart.GetBodies2(swAllBodies, False)
                      If IsEmpty(vBodies) Then Exit Sub
                      For i = 0 To UBound(vBodies)
                          Set swConfig = swModel.AddConfiguration3(vBodies(i).Name, Empty, Empty, Empty)
                          colConfigName.Add swConfig.Name
                          swModel.Extension.SelectByID2 vBodies(i).Name, "SOLIDBODY", 0, 0, 0, False, 0, Nothing, 0
                          Set swFeat = swModel.FeatureManager.InsertDeleteBody
                          colDeleteBodyName.Add swFeat.Name
                      Next i
                      For i = 1 To colConfigName.Count
                          swModel.ShowConfiguration2 colConfigName.Item(i)
                          For j = 1 To colDeleteBodyName.Count
                              Set swFeat = swPart.FeatureByName(colDeleteBodyName.Item(j))
                              If j = i Then
                                  swFeat.SetSuppression2 swSuppressFeature, swThisConfiguration, Empty
                              Else
                                  swFeat.SetSuppression2 swUnSuppressFeature, swThisConfiguration, Empty
                          Next j
                      Next i
                      swModel.ShowConfiguration2 strOriginalConfigName
                  Keith
                  1 person found this helpful
                      Yong Ning
                      IsSuppressed2→true and false | SOLIDWORKS Forums
                      https://forum.solidworks.com/thread/89449
                      Private Sub main()
                        Dim Swapp As SldWorks.SldWorks
                        Dim SwModel As SldWorks.ModelDoc2
                        Dim SwFeat As SldWorks.Feature
                        Dim vConfArr As Variant
                        Dim vConfBool As Variant
                          Set Swapp = Application.SldWorks
                          Set SwModel = Swapp.ActiveDoc
                          Set SwFeat = SwModel.FeatureByName("Hole")
                          Debug.Print "Feature: " & SwFeat.Name
                          vConfArr = SwModel.GetConfigurationNames
                          vConfBool = SwFeat.IsSuppressed2(swInConfigurationOpts_e.swSpecifyConfiguration, vConfArr)
                          For i = 0 To UBound(vConfArr)
                              Debug.Print "Configuration: " & vConfArr(i) & "  Suppression: " & vConfBool(i)
                          Next i
                          SwFeat.SetSuppression2 swSuppressFeature, swAllConfiguration, vConfArr
                          Stop
