10 Replies Latest reply on Jan 9, 2015 3:20 AM by Markku Lehtola
    Excel Based BOM macro to save file
    Mark Stillman
      HI all,
      we have just stared to use the Excel Based BOM function in Solidworks 2014. This solves a load of issues for us and is actually useful.
      I was wondering how to create a macro to save the bom to a specific folder on out network. Ive tried running the macro recorder but it doesn't make any sense
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("@Drawing View1", "BOM", 9.80850184849844E-02, 0.344196913033501, 0, False, 0, Nothing, 0)
      I would like to just click a macro and it save to my e:\documents\BOM\ folder with the document name and the version number if possible.
      I would appreciate some help with this please.
      Thanks in advance
      Mark
        • Re: Excel Based BOM macro to save file
          Keith Rice
          Mark,
          How are you saving an Excel-based BOM via the GUI? I don't see any option to save the BOM when I right click on it.
          Unfortunately, I don't think this is possible via the API. The only way to get the API object for an Excel-Based BOM table is through IView::GetBomTable, but this API call is deprecated. I tested it in 2013 and it didn't work. I'm not sure why no additional API calls were created to work with Excel-based BOMs. You could email SolidWorks API support and request this functionality if you wanted. (Not going to happen, since this functionality is deprecated. See Josh Brady's comment below.
          Keith
          SolidWorks API Video Tutorials
              Mark Stillman
              hi Keith,
              thanks for the reply
              you have to click to highlight the BOM and then go File> Save as , the dialog comes up automatically with xlsx.
              it seems like the whole thing is a half implemented piece.
              Your supposed to be able to add summary info into the bom and I've followed the vague instructions to try and add the document name to the excel sheet but it doesn't do anything.
              you can link the excel sheet to the file but its not much use once you put into the pdm vault.
              contacted solid solutions but they didn't have much of an idea on what to do with it either.
              Mark
                Daniel Andersson
                Keith,
                Just a thought. Wouldn't it possible to access the BOM with ITableAnnotation and then process each cell by code and write it to an excel file (using Excel API)?
                If that works the only thing is the formatting etc that needs to be handled as well... which makes the code to be a lot more compared to if there would have API functions to just export it.
                Bill Florac
                This can be done but it can be tricky.  You have to manually get the assembly, get the current configuration (or the one you want) and drill down to all it's parts. Along the way, you need to check to make sure that the part is not "excluded from the BOM" and a few other flags (virtual, hidden, suppressed, envelope..) to make sure that you want this part. It gets even more complicated if you have cut lists and such. You may want or need to drill down to the next level too. All this is done for you when you put the BOM on the drawing and save it as an excel spread sheet. I do all this with the Solidworks Document Management API but I'm sure it can be done with the Solidworks API too.
                Get Document
                     Get Document - Config
                          Get Config - Components
                               Check Component
                                    Add to Excel
                  Adam Hoffman
                  Try having a look at this thread:
                  Macro: Generate BOM, Export to Excel
                  This is the only way I have found to save a BOM out as an Excel file with the API. If you need it in a specific format, then you will have to use the other suggestions and traverse the assembly and create an Excel workbook piece by piece with a lengthy program. Hope this helps.
                    Mark Stillman
                    Hi sorry for not getting back sooner been on Christmas holidays +5.
                    Thinks there is some confusion, maybe my fault with what im describing.
                    Solidworks 2014 has an Excel Based Bill of Materials which makes a link to a excel spread sheet.
                    The only way you can save the excel sheet is to click on the bom then select Save As and then save it as an Excel file
                    I have a macro which is a hacked about version of Lenny Kikstra's Document Export, which saves all the file formats I need into a shared directory on our net work, JPG, PDF, DWG,DXF etc and SAT models.
                    Anyway im trying to add the bom save section into it.
                    Ive tried recording a macro of selecting the BOM then the save as but it doesn't seem to come up.
                    Dim swApp As Object
                    Dim Part As Object
                    ______________________________________________
                    Set swApp = _
                    boolstatus = Part.Extension.SelectByID2("@Drawing View1", "BOM", 0.123688849057995, 0.327034678124557, 0, False, 0, Nothing, 0)
                    this seems to only select the bom and nothing else.
                    if I go via Feature manager and right click on the Bill of materials! icon and do edit I get this
                    Dim swApp As Object
                    Dim Part As Object
                    _______________________________________________
                    Set swApp = _
                    boolstatus = Part.Extension.SelectByID2("@Drawing View1", "BOM", 0, 0, 0, False, 0, Nothing, 0)
                    Dim myModelView As Object
                    Set myModelView = Part.ActiveView
                    myModelView.FrameState = swWindowState_e.swWindowMaximized
                    Part.ClearSelection2 True
                    this opens the bom in this window
                    which I think is an excel screen via active X ( not to good with this stuff hence post)
                    sorry for the long post
                    Mark
                        Josh Brady
                        What is it about Excel-based BOMs that you like?  Can the functionality be done with a regular SolidWorks BOM?
                        The reason I ask is that Excel-based BOMs have been obsolete and pretty much unsupported since like SW2005 or something. They haven't been removed from the software, but haven't been developed either.  Programmatically, there's a whole lot more that can be done with SolidWorks BOMs, and they can easily be saved as Excel files.  I would highly recommend not using Excel-based BOMs.  With every release of SW I keep expecting them to be gone.
                        Markku Lehtola
                        this saves SW-bom as txt file, it's easy to add filename stuff for it
                        Set DrawDoc = swApp.ActiveDoc
                        Set View = DrawDoc.GetFirstView
                        Set TableAnn = View.GetFirstTableAnnotation
                        Do While Not TableAnn Is Nothing
                            If TableAnn.Type = 2 Then '2 is the bom table type
                                Set BOM = TableAnn
                                Exit Do
                            Set TableAnn = TableAnn.GetNext
                        Loop
                        If BOM Is Nothing Then
                            MsgBox "BOM was not found"
                        Else
                            Dim Txt As String
                            Dim Row As Long
                            Dim Col As Long
                            Dim fso As New FileSystemObject
                            Dim ts As TextStream
                            Set ts = fso.CreateTextFile("C:\test.txt", True)
                            For Row = 0 To BOM.RowCount - 1
                            Txt = Empty
                                For Col = 0 To BOM.ColumnCount - 1
                                   Txt = Txt & BOM.Text(Row, Col) & ";"
                                Next Col
                                ts.writeline (Txt)
                            Next Row
                            ts.Close
                        MsgBox "Done!"
                        references:
                        br
                        Markku
                        www.sloworks.fi
