7 Replies Latest reply on Dec 22, 2014 4:58 PM by Dallas Havens
    Save as PDF but check for open document first
    Dallas Havens
      I have compiled some code from several posts on this forum to create a macro that will save a document and then if the document is a drawing save a PDF file in the same location. The macro works great but the only problem is that if the pdf file already exists and is open by me or another user it hangs up until the file is closed.
      Is there a way to check to see if there is a pdf by the same name already open by someone and bring up a dialog box that will notify the user and give a choice to either continue or exit?
      Attached is the macro I am currently using.
      Thanks in advance for any help you may provide.
      Message was edited by: Dallas Havens
        • Re: Save as PDF but check for open document first
          Daniel Andersson
          Check out this information an code from Microsoft. Macro code to check whether a file is already open
          As an option, this information is also available from Microsoft. WD2000: VBA Function to Check Whether File or Document Is Open
          Next thing to add is a messagebox with option, vbOkCancel to get a Ok and Cancel button.
          That part of the code look like this...
          Dim iRetVal As Integer
          iRetVal = MsgBox("Text goes here..." & "Another text string", vbOkCancel)
          If iRetVal = 1 Then
               'User clicked Ok at messagebox
          Else
               'User clicked Cancel at messagebox
          You may also choose if a icon should appear in the message box:
          iRetVal = MsgBox("Text goes here..." & "Another text string", vbOkCancel + vbInformation)
          Alternatives to vbInformation is vbCritical, vbQuestion and vbExclamation
          You may also set a title to the dialog:
          iRetVal = MsgBox("Text goes here..." & "Another text string", vbOkCancel, "Your title")
          For further information about MsgBox, see the help file in the VBA editor.
          Please let me know if you need any further help.
              Dallas Havens
              Hi Daniel,
              Thanks for the info, I will look into it.
                Dallas Havens
                Hi Daniel,
                I know that it has been a few days since I posted but I've been working on another project. This is a bit of a side pet project but I have very little experience writing code. I used the info you provided above to modify my code to try and get it to check to see if the PDF is open before it saves. I also added the code you provided to bring up the message box and I attempted to use a loop to have it recheck for the open file upon clicking ok.
                The problem is that when I run the macro I get a compile error on the "IsFileOpen" command. It says "Sub or Function not defined". I have coppied the modified macro below.
                As I said before, I have very little experience writing code so any help that you will be willing to give will be greatly appreciated.
                Thanks in advance.
                'File Save As PDF & DWG.swp -------------03/18/13
                'Description: Macro to save active drawing as PDF and DWG.
                'Precondition: Any active drawing to be saved.
                'Postcondition: Active drawing will be saved as PDF and DWG in the same location as drawing.
                ' Please back up your data before use and USE AT OWN RISK
                ' This macro is provided as is.  No claims, support, refund, safety net, or
                ' warranties are expressed or implied.  By using this macro and/or its code in
                ' any way whatsoever, the user and any entities which the user represents,
                ' agree to hold the authors free of any and all liability.  Free distribution
                ' and use of this code in other free works is welcome.  If any portion of
                ' this code is used in other works, credit to the authors must be placed in
                ' that work within a user viewable location (e.g., macro header).  All other
                ' forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
                ' without the expressed written consent by the authors.  Use at your own risk!
                ' Written by: Deepak Gupta (http://gupta9665.wordpress.com/)
                Dim swApp        As SldWorks.SldWorks
                Dim swModel      As SldWorks.ModelDoc2
                Dim swDraw       As SldWorks.DrawingDoc
                Dim Filepath     As String
                Dim FileName     As String
                Dim boolstatus As Boolean
                Set swModel = swApp.ActiveDoc
                ' Is document active?
                If swModel Is Nothing Then
                    swApp.SendMsgToUser2 "A document must be active.", swMbWarning, swMbOk
                    Exit Sub
                'Save Document
                swModel.Save
                ' Is it a Drawing document?
                If swModel.GetType <> swDocDRAWING Then
                    Exit Sub
                Set swDraw = swModel
                Filepath = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\"))
                FileName = Left(swDraw.GetTitle, Len(swDraw.GetTitle) - 9)
                    ' Test to see if the file is open.
                    Do
                    If IsFileOpen(Filepath + FileName + ".PDF") Then
                        ' Display a message stating the file in use.
                        iRetVal = MsgBox(Filepath + FileName + ".PDF is in use by you or another user." & "Make sure the file is no longer open" & "or click cancel to exit without updating PDF file.", vbOKCancel)
                        If iRetVal = 1 Then
                            Loop
                        Else
                        ' Add code here to handle case where file is open by another
                        ' user.
                    Else
                        ' Display a message stating the file is not in use.
                        MsgBox "File not in use!"
                        ' Save document as PDF.
                        swDraw.SaveAs (Filepath + FileName + ".PDF")
                        ' Add code here to handle case where file is NOT open by another
                        ' user.
                Charles Winter
                Here is the part of our code that checks that.
                iResponse = MsgBox("The PDF will be saved to..." + Chr(13) + FileSave + Chr(13) + Chr(13) + "Is this correct?", vbYesNo + vbQuestion, "PDF will be saved to...")
                    If iResponse = vbNo Then
                        errorfinish = True
                        GoTo Finish
                    Else
                    ' Checks if PDF file already exist in the directory
                    Set fso = CreateObject("Scripting.FileSystemObject")
                    If fso.FileExists(FileSave) = True Then
                        iResponse = MsgBox("A PDF for '" & Filename & "' already exist, are you sure you want to overwrite the file?", vbYesNo + vbQuestion + vbDefaultButton2, "File Exist")
                        If iResponse = vbYes Then
                        ' Checks to see if the file is open
                            If FileLocked(FileSave) Then
                               MsgBox "'" + FileSave + "' is open by you or another user.  Please close the file and re-run the macro.", vbOKOnly + vbExclamation, "File Is Open"
                               errorfinish = True
                               GoTo Finish
                        Else
                            errorfinish = True
                            GoTo Finish
                    Dallas Havens
                    I added the above code to my macro but I got a compile error on the "If FileLocked" line. Says Sub or Function not defined. I copied the macro below.
                    Also I don't need to check file location or if file name exist, just if it is open. instead of a measage box I would like a selection box with ok and cancel where ok rechecks for the open file and the cancel exits the macro. If the file is not open then it should continue to save or replace the existing PDF.
                        Exit Sub
                    'Save Document
                    swModel.Save
                        Exit Sub
                            errorfinish = True
                            GoTo Finish
                        Else
                            iResponse = MsgBox("A PDF for '" & FileName & "' already exist, are you sure you want to overwrite the file?", vbYesNo + vbQuestion + vbDefaultButton2, "File Exist")
                                    errorfinish = True
                                    GoTo Finish
                            Else
                                errorfinish = True
                                GoTo Finish
