Sketch relations icons display directly over the relations they are referring to.
In previous versions of SW, the relation icons would be placed near the actual relation they were referring to. For instance, if two points have a symmetric relation, the icons would display near the points but not actually on the points. A horizontal or vertical relation would display next to a line but not on it. Here is an example of what it should look like.
Now, for some reason, the relation icons are displaying directly over the relations they are referring to. Sometimes they will obstruct each other if there are two relations at one point. In the image below, I added a parallel and equal relation to the lines in the rectangle and they are obstructing the vertical and horizontal relations previously shown. The perpendicular icon obstructs the intersection point on the corner.
I have not been able to find any way to change this in the options. Is it possible to change where the sketch relations display?
I'm not seeing the same behavior here. Using 2015 SP1.1.
What version are you on?
