2 Replies Latest reply on Dec 17, 2014 12:05 AM by Brandon Massoni
    How to store selected features in an array?
    Brandon Massoni
      How can I store selected features (edges in my case) in an array? I keep getting "error 9, subscript out of range."
      'Precondition: Edges are selected
      'Post-condition: Edges are stored in an array "swEdge()"
      Option Explicit
      Dim longEdgeCount As Long
      Dim swEdge() As SldWorks.Edge
      Dim swEnt As SldWorks.Entity
      Dim Bret As Boolean
      Dim i As Integer
          Set swModel = swApp.ActiveDoc
          'Zero edge counter, find edge count value,& subtract 1 to match array index
          longEdgeCount = 0
          longEdgeCount = swSelMgr.GetSelectedObjectCount2(-1) 'Select regardless of marks
          MsgBox longEdgeCount
          longEdgeCount = longEdgeCount - 1
          'Set selectedObjects to objEdge() array
          For i = 0 To longEdgeCount
              Set swEdge(i) = swSelMgr.GetSelectedObject6(i + 1, -1)
          Next
          'Check to see if swEdge is populated correctly
          swModel.ClearSelection2 True
              Set swEnt = swEdge(i)
              Bret = swEnt.Select4(True, swSelData): Debug.Assert Bret
          Next
        • Re: How to store selected features in an array?
          Keith Rice
          Brandon,
          The reason you are getting that error is because your array, swEdge, is dynamic, and dynamic arrays by default have no length. You need to use ReDim to specify an array size before you start assigning values to its elements. For example, this will resize the array so that it can hold the number of items selected:
          ReDim swEdge(swSelMgr.GetSelectedObjectCount2(-1) - 1)
          ReDim resets the entire array. You will need to use ReDim Preserve if you want to preserve existing elements.
          But wait! I would not recommend that you use arrays at all. Rather, use the Collection class, which is much easier to work with. When you declare a collection you will need to use the New keyword, as shown below, because a collection is a class, and classes need to be instantiated. Also be sure to reset your collection each time you run your program.
          Here is how I would recommend you write this macro:
          'Post-condition: Edges are stored in collection "colEdges"
          Option Explicit
          Dim colEdges As New Collection
          Dim i As Integer
              Set colEdges = Nothing
              For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
                  colEdges.Add swSelMgr.GetSelectedObject6(i, -1)
              Next
              For i = 1 To colEdges.Count
                  Set swEnt = colEdges.Item(i)
                  swEnt.Select4 True, Nothing
              Next
              Stop
          Finally, on a semantic note: "features" refer only to items that reside in a FeatureManager tree. Since edges cannot reside there, they are not considered features. Technically, an edge is an topological entity.
          I hope this helps.
          Keith
          SolidWorks API Video Tutorials
          1 person found this helpful
