Select Files in Folder That Contain...
Question asked by Craig Ashmore on Dec 16, 2014
Latest reply on Dec 16, 2014 by Daniel Andersson
I've pulled this code from online to replace sheet formats of drawings in a specified directory.  I'm looking to add in a parameter that searches the filename and only runs the code on the drawings within that folder that meet the criteria.
Basically I have drawings that have file names that look like this: 317-T1001-SG-1-ISO.slddrw and another might have 317-T1001-PL-1-FAB.slddrw
I only want the code to run on the file names that contain "ISO" and skip ones that do not, ie "FAB"
Below is the code: (please forgive my formatting)
Option Explicit
Dim swModel As ModelDoc2
Dim swFilename As String
Dim swSheet As SldWorks.Sheet
Dim bRet As Boolean
Dim sPath As String
Dim nErrors As Long
Dim nWarnings As Long
Dim Response As String
Dim DocName As String
' Change sheet format location here
Public Const sTemplatePath As String = "C:\Solidworks Reference\Document Templates\"
' Change folder location containing the drawings to be updated here
SheetFormat "C:\Users\Cosmos II\Desktop\Focal Point Design\Clients\HydraFab\XXX-To Library\test\", ".SLDDRW", True
Sub SheetFormat(folder As String, ext As String, silent As Boolean)
Dim swDocTypeLong As Long
ext = UCase$(ext)
swDocTypeLong = Switch(ext = ".SLDDRW", swDocDRAWING, True, -1)
'If not a SW file, return
If swDocTypeLong = -1 Then
Exit Sub
ChDir (folder)
Response = Dir(folder)
Do Until Response = ""
swFilename = folder & Response
If Right(UCase$(Response), 7) = ext Then
  Set swModel = swApp.OpenDoc6(swFilename, swDocTypeLong, swOpenDocOptions_Silent, "", nErrors, nWarnings)
  If swDocTypeLong = swDocDRAWING Then
Set swDraw = swModel
    Set swSheet = swDraw.GetCurrentSheet
' Change Sheet format name here which you to put on the drawing sheet.
sPath = sTemplatePath & "HydraFab Iso1.slddrt"
bRet = swDraw.SetupSheet4(swSheet.GetName, swDwgPaperAsize, swDwgTemplateCustom, 1, 1, False, sPath, 0.2794, 0.2159, "Default")
  swModel.ViewZoomtofit2
  swModel.ForceRebuild3 False
  swModel.Save2 silent
  swApp.CloseDoc swModel.GetTitle
Response = Dir
Loop
MsgBox "Drawing(s) Sheet Fomat Updated!!"
