ZGZenjoe Green25/04/2007
I am having a problem with my hole wizard. I loaded a part (with noerrors) and changed the depth of a hole wizard hole and then thiserror message popped up.
"The intended cut does not intersect the model. Please checkthe sketch and direction."
All I did was change the depth of the hole, I did not touchanything else. Anyway, I clicked the Undo button and it still showsthe error.
I looked at the sketch and I could not find any problems. On the 3dsketch, I made sure that all the hole locations were on the surfaceI wanted them to be on. On the 2D sketch, I verified that it wasdrawn with the correct direction and the start point was coincidentto the point where I had added the "on surface" reference(from the 3d sketch).
I have encountered this problem several times in the past. but Ihave a lot of parts mated to this particular feature and I do notwant to remate everything if I were to delete and redo theholes.
any suggestions?
I am on SW SP 3.0
