How the versions of ECAD files are maintained in EPDM ?
Is there any relationship maintained in EPDM for PRJPCB with its contents ?
Files which are related to PRJPCB file is not updating in EPDM vault if I change the version of PRJPCB file.
Some files in PRJPCB files contains no data when changing the version of the PRJPCB file using EPDM. In this situation how we have to handle the data while version migration?.
Thanks in Advance!!!
Hi Lingashetty Menasagi,
there's no builtin EPDM fileplugin for Altium Designers prjpcb files and EPDM can't read references and properties.
You have to write EPDM fileplugin for a such things to be available. Though you can access some properties through standard INI fileplugin by adding prjpcb extension to INIplugin on the client's computer registry. Just create registry brunch
HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise\FileFormats\.prjpcb
and add REG_MULTI_SZ key 8 with value IniPlugin.dll (use FileFormats\.ini brunch as a an example).
Then you can add variable mapping for prjpcb files.
prjpcb stores properties data like that:
[Parameter5]
Name=ProjectAssyNum
Value=D-820-0014
so block name will be Parameter5 and attribute name Value.
As parameters order can vary if create AD project from scratch, you have to use templates for every new project.
References should be added by hand in this case.
