Can we make a simulation Weld on solids and shells. Whether the results Produced by Shell surface will be equal to Solid Weld. ( Thickness mentioned in shell will be same as solid thickness.)
Immediate Reponses will be Appreciated.
Regards
Saravanan R
Have you looked at the edge weld definitions ? see here 2014 SOLIDWORKS Help - Edge Weld Definitions
Some info on youtube also e.g. here Weld Check Using SolidWorks Simulation - YouTube
