2 Replies Latest reply on Feb 18, 2015 4:53 PM by Richard Cook
    Please show me how to select the "known" point in the first sketch so I can add the relation. VBA
    Richard Cook
      Please see this VBA macro...
      I can't figure out how to select the first point by using the ID and sketch name....
      This should be simple...
      Please someone help.
      Thanks... Richard
      == Copy and past below.  Run this macro in a part.  Nothing selected
      Option Explicit
      Dim swApp As Object
      Dim swModelDocExt As SldWorks.ModelDocExtension
      Dim swSketchMgr As SldWorks.SketchManager
      Dim swSelData As SldWorks.SelectData
      Dim skLine As SldWorks.SketchLine
      Dim skPoint As Object
      Dim vSketchPtID  As Variant
      'make a storage structure
      Public Type PointStore
           id0 As Long
           id1 As Long
           skName As String
           X As Double
           Y As Double
           Z As Double
      End Type
      Dim mySavedPoint As PointStore
      Dim boolstatus As Boolean
      Set swModel = swApp.ActiveDoc
      Set swSketchMgr = swModel.SketchManager
      ' make a new blank Sketch
      swSketchMgr.Insert3DSketch True
      'make a point in the sketch and add fix relation
      Set skPoint = swModel.SketchManager.CreatePoint(2.3, 3.3, 1.25)
      swModel.SketchAddConstraints "sgFIXED"
      vSketchPtID = skPoint.GetID
      mySavedPoint.id0 = vSketchPtID(0)
      mySavedPoint.id1 = vSketchPtID(1)
      mySavedPoint.skName = swSketchMgr.ActiveSketch.Name
      mySavedPoint.X = skPoint.X
      mySavedPoint.Y = skPoint.Y
      mySavedPoint.Z = skPoint.Z
      'close this sketch
      swModel.ClearSelection2 True
      'create new 3DSketch
      Set swSelData = swSelMgr.CreateSelectData
      ' Draw a line ..
        Set skLine = swSketchMgr.CreateLine(mySavedPoint.X, mySavedPoint.Y, mySavedPoint.Z, 5#, 5#, 5#)
      'select the line just created's endpoint
        boolstatus = skLine.GetStartPoint2.Select4(False, swSelData)
        'Or other end '''boolstatus = skLine.GetEndPoint2.Select4(True, swSelData)
        ' So now the line endpoint is selected.
        ' And I have the persistant data from the first sketch's point...
            Debug.Print mySavedPoint.skName & vbCrLf & "IDPt = [" & _
                     mySavedPoint.id0 & ", " & _
                     mySavedPoint.id1 & "]" & vbCrLf & _
                     "Cordinate (" & mySavedPoint.X * 1000# & ", " & _
                     mySavedPoint.Y * 1000# & ", " & _
                     mySavedPoint.Z * 1000# & ") mm  "
      ''' How to add this point to the selection set and make the 2 coincident??
      MsgBox ("How now to select the first sketch point and make coincident?")
        • Re: Please show me how to select the "known" point in the first sketch so I can add the relation. VBA
          Richard Cook
          So finally....  How "GetID function can be used in Selecting a known point"
          I included some code snips below ....
          The GetID Method (ISketchPoint) returns an Array with two longs or two integers...
          The second element in the return array seems to correspond to the number in the selection name...
          So in the plotpoints function (below) the sketch point name is...
          myPointCount(i).skPtName = "Point" + CStr(vSketchPtID(1)) + "@" + swSketchMgr.ActiveSketch.Name
          .. Becomes something like "Point5@Sketch1"
          So now to select it later (add to selection set) by the exact name ...
          boolstatus = swModelDocExt.SelectByID2(myPointCount(i).skName, "EXTSKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0)
          --- So far this has worked..
              id0 As Long
              id1 As Long
              skPtName As String
              X As Double
              Y As Double
              Z As Double
          End Type
          Dim myPointCount(20) As PointStore
          Main()
          vSketchPtID = plotPoints(0, 0, 0, 0, swSketchMgr.ActiveSketch.Name)
          Function plotPoints(i, X, Y, Z, skName) As Variant
          Set skPoint = swModel.SketchManager.CreatePoint(X, Y, Z)
                Debug.Print "  IDPt(" & i & ") = [" & _
                        vSketchPtID(0) & ", " & _
                        vSketchPtID(1) & "]"
                Debug.Print "    (" & _
                        skPoint.X * 1000# & ", " & _
                        skPoint.Y * 1000# & ", " & _
                        skPoint.Z * 1000# & ") mm"
            myPointCount(i).id0 = vSketchPtID(0)
            myPointCount(i).id1 = vSketchPtID(1)
            myPointCount(i).X = skPoint.X
            myPointCount(i).Y = skPoint.Y
            myPointCount(i).Z = skPoint.Z
          plotPoints = vSketchPtID
          End Function
            Richard Cook
            Also...
            Some more guessing on my part about the array values..
            The second element in the return array correspond to the number in the selection name -- like "Point2@Sketch1"
            The first element seems to be the current position (order) in the sketch..
            So if you created 5 points in a sketch, the values returned would be (0,1),(1,2),(2,3),(3,4),(4,5)..
            If you delete those points and create 5 more, the new ID's would be (0,6),(1,7),(2,8),(3,9),(4,10).
