I am using SW 2014 SP 3.0
I am trying to achieve this without having to unfold and extrude cut.
Any ideas would be much appreciated.
Randy
Randy
Hi Randy,
the only way to achieve this is the manual way you mentioned in your post. If this is a common requirement for you, you could try to create a library feature that can be easily placed (but you would still have to unfold/fold the bends).
The Corner Relief feature is currently limited to 2 bend corners.
There is currently an existing enhancement request. Perhaps you want to log in to the SolidWorks Customer Portal and vote for this enhancement. When you search for "No ability to do a 3 bend corner relief" you will easily find this enhancement and you can simply vote on it.
Enhancement requests with lots of customers asking for it get more likely implemented .
Kind regards
Frank
Hi Randy,
Kind regards
Frank
