6 Replies Latest reply on Jun 30, 2015 2:59 PM by Lee Priest
    EPDM API - checking out a file already opened in SolidWorks
    tyty tyty
      • Is there a way to check out a document when the file is open in SolidWorks? I’m trying to check out a part or assembly from an opened drawing. The highlighted line doesn’t work if the file is opened as a reference.
          Sub epdmCheckOutFile(ByVal strFileName As String)
              Dim folder As EdmLib.IEdmFolder5 = Nothing
              Dim file As EdmLib.IEdmFile5 ' = folder.GetFile(strFileName)
              file = pdmVault.GetFileFromPath(strFileName, folder)
              Try
                  Dim RetVal As MsgBoxResult
                  RetVal = MsgBox("Do you want to check out " & file.Name, MsgBoxStyle.YesNo, "Vermeer Tools - Check Out File")
                  If RetVal = MsgBoxResult.Yes Then
                      file.LockFile(folder.ID, 0)
              Catch ex As Exception
                  MessageBox.Show("Unable to check out " & strFileName, "File Check Out Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
              End Try
          End Su
        • Re: EPDM API - checking out a file already opened in SolidWorks
          Adam Hoffman
          Here is what I currently use in a stand alone .exe program:
          Private Sub CheckOutFile(ByVal DrawingModel As SldWorks.ModelDoc2, ByVal FullFileNameToCheckOut As String, ByVal CurrentConFig As String)
                  Dim vault As New EdmVault5
                  Dim vaultname As String = "Your Vault Name Here"
                  vault.LoginAuto(vaultname, 0)
                  Dim userMgr As IEdmUserMgr5
                  userMgr = vault
                  Dim user As IEdmUser5
                  user = userMgr.GetLoggedInUser
                  Dim sUser As String = CStr(user.Name)
                  Dim aFolder As IEdmFolder5 = Nothing
                  Dim aFile As IEdmFile5 = vault.GetFileFromPath(FullFileNameToCheckOut, aFolder)
                  If aFile IsNot Nothing Then
                      Dim bLocked As Boolean = aFile.IsLocked
                      If bLocked = False Then
                          Try
                              Dim iRelease As Integer = DrawingModel.ForceReleaseLocks()
                              If iRelease = 1 Then
                                  Dim iMyHandle As Integer = GetMyHandle()
                                  aFile.LockFile(aFolder.ID, iMyHandle, 0)
                                  iRelease = DrawingModel.ReloadOrReplace(False, DrawingModel.GetPathName, False)
                              ElseIf iRelease = 0 Then
                                  Dim bResult As DialogResult = MessageBox.Show("There Was An Error Trying To Check Out The Specified File" + vbNewLine + "Please Check Out The File And Click OK", "Check-Out Error", MessageBoxButtons.OKCancel)
                                  If bResult = Windows.Forms.DialogResult.Cancel Then
                                      Application.Exit()
                                      End
                          Catch CheckOutError As Exception
                              Debug.WriteLine(CheckOutError)
                          End Try
                      ElseIf bLocked = True Then
                          Dim aLockedBy As IEdmUser5 = aFile.LockedByUser
                          Dim sLockBy As String = CStr(aLockedBy.Name)
                          If Not UCase(sLockBy) = UCase(sUser) Then
                          MessageBox.Show("The File Is Checked Out By: " + sLockBy + vbNewLine + _
                                                           "Please Ask Them To Check In The File", "Check-Out Error", MessageBoxButtons.OKCancel)
            Lee Priest
            I don't know if anyone has found this, but I couldn't get ForceReleaseLocks to work with drawing files. Turns out, this is normal behavior and you need to use the CloseAndReopen function. More info here: 2012 SOLIDWORKS API Help - CloseAndReopen Method (ISldWorks)
