Hello
I'm currently running into an issue with solidworks. I try to tangentially connect a tube to a sheetmetal tube.
I'm trying to get a tangential connection of the inner diameter of the connection tube to the sheetmetal tube.
With a cut extrude i need to use a projection, this doesn't give the desired shape.
With the wrap feature I need to project the 3D sketch to a plane, so this doesnt give the right shape either.
What needs to be removed is shown in a 3D sketch, what's the correct way to solve this problem.
Thanks in advance, Mark.
Have a look at my image, and the post here: Sheet metal - Normal Cut Issues
