I'm having an issue with global variables while using the micron scale. For instance: if i set a global variable = 10um, the 'evaluates to' tab says 10000nm, but on the actual sketch it evaluates to 10000um. See picture below:
Does anyone know how to remedy this issue?
I've had this problem for a while. I used to solve it my exiting the sketch and reopening it, which would cause the dimension to correct itself. Since i upgraded from 2013 -> 2015, this solution no longer works.
Thanks!
I solved the issue. In the "value/equation" box, the issue is solved if I remove the 'um' characters from the equation.
This still looks like a solidworks bug since the equation didn't evaluate properly.
