Both sketches are parallel with lines horizontal or vertical. I also added guide curves (straight lines) on each edge and middle to middle of each rectangle, but this did not help. How are the sides not flat/planer and how do I get them this way?
What do you have the start/end conditions set to? None (start/end constraint) would be my best guess without seeing a picture of what you're describing. Also you can turn on the connectors to make sure your loft isn't twisting at all. To do this, right click in the user interface and chose show all connectors. You can click and drag those connectors along the sketch segments to change how the loft is created.
