2 Replies Latest reply on Dec 9, 2014 7:30 PM by Yong Ning
    How to get the feature name of Cut-Extrude?
    Yong Ning
      How to obtain sketh name? | SOLIDWORKS Forums
      https://forum.solidworks.com/message/339500#339500
      Sketch →
              Set SwFeat = .GetActiveSketch
              SwFeat.Select True
              Debug.Print SwFeat.Name
      Help me
      FeatureManager.FeatureCut → How to get feature name of Cut-Extrude1 name?
      Private Sub ll()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
           Set SwApp = Application.SldWorks
           Set SwModel = SwApp.ActiveDoc
        Dim SwSelMgr As SelectionMgr, Tmp
           Set SwSelMgr = SwModel.SelectionManager
        Dim SwAnn As Annotation, S As Sketch
           With SwModel
              Tmp = .Extension.SelectByID2("", "Face", 0, 0, 0, False, 0, Nothing, 0)
              .CreateCircleByRadius2 0, 0, 0, 0.025
              .FeatureManager.FeatureCut True, False, False, 1, 0, 0.01, 0.01, False, False, False, False, 0, 0, False, False, False, False, 0, 1, 1
           End With
        • Re: How to get the feature name of Cut-Extrude?
          Daniel Andersson
          Try:
          Private Sub ll()
               Dim swFeature as Sldworks.Feature
               Tmp = SwModel.Extension.SelectByID2("", "Face", 0, 0, 0, False, 0, Nothing, 0)
               SwModel.CreateCircleByRadius2 0, 0, 0, 0.025
               Set swFeature = SwModel.FeatureManager.FeatureCut3(True, False, False, 1, 0, 0.01, 0.01, False, False, False, False, 0, 0, False, False, False, False, 0, 1, 1, False, False, False, 0, 0, False)
               debug.print swFeature.Name
          FeatureCut is obsolete. Use FeatureCut3 that is available since SW2009 SP4. FeatureCut3 also returns a feature (IFeature interface).
              Yong Ning
              Thanks your code.
              Function FeatureCutOfCircle(SwModel As ModelDoc2, ViewName, cutNameArr, R)
                Dim SwFeat As Feature, SketchFeat As Feature
                   With SwModel
                      Tmp = .Extension.SelectByID2(ViewName, "PLANE", 0, 0, 0, False, 0, Nothing, 0)
                      For ii = 0 To UBound(cutNameArr)
                         .CreateCircleByRadius2 0, 0, 0, R / 1000
                         .ClearSelection2 True
                         Set SketchFeat = .GetActiveSketch
                         SketchFeat.Select True
                         SketchFeat.Name = cutNameArr(ii) & "_" & ii
                         Debug.Print SketchFeat.Name
                         Set SwFeat = .FeatureManager.FeatureCut(True, False, False, 1, 0, 1, 1, False, False, False, False, 0, 0, False, False, False, False, 0, 1, 1)
                         SwFeat.Name = cutNameArr(ii)
                         SwFeat.Select True
                         .EditSuppress2
                      Next ii
                    End With
              End Function
              Private Sub del()
                Dim Xls As Excel.Application
                   Set Xls = GetObject(, "Excel.Application")
                Dim Rng As Range, Arr()
                   Set Rng = Xls.Selection
                   nn = Rng.Rows.Count - 1
                ReDim Arr(nn)
                   For ii = 0 To nn
                      Arr(ii) = Rng(ii + 1, 1)
                   Next ii
                Dim ViewName
                   ViewName = "前视基准面"
                  FeatureCutOfCircle SwModel, ViewName, Arr, 25
