Unsure how to create this geometry
Question asked by Kody Spaberg on Dec 6, 2014
Latest reply on Dec 6, 2014 by Kelvin Lamport
I'll try to explain what I'm trying to achieve and I'll also post some pictures to further explain. Pretty much I'm trying to make a cut in a circular shape that is drafted inward at 118 degrees. I'm limited by the fact that you can only Extrude Cut and Draft by 90 degrees at the most. So clearly I need to find another method. I could make the smaller hole cut and then Chamfer it to 118 degrees but I don't know the inside circles dimension. The original file I'm using as a reference lists these holes as "Tap Drill". Are there pre-made drill holes I can use? Here are two pictures to help explain:  http://imgur.com/a/ZeIIE
