3 Replies Latest reply on Dec 13, 2014 2:33 AM by Yong Ning
    How to Loading Table Driven Patterns with API?
    Yong Ning
      Hope use API., Loading table Driven Pattern
      To load a table-driven pattern instance:
      With a part open, click Table Driven Pattern  (Features toolbar) or Insert > Pattern/Mirror > Table Driven Pattern.
      Click Browse to locate the .sldptab file, then click Open.
      The file name appears in Read a file from, along with the X-Y coordinates.
      Select the appropriate Reference point and Coordinate system.
      2014 SOLIDWORKS Help - Saving and Loading Table Driven Patterns
      http://help.solidworks.com/2014/english/solidworks/sldworks/c_Saving_and_Loading_Table_Driven_Patterns.htm
        • Re: How to Loading Table Driven Patterns with API?
          Yong Ning
          Why can't run code→
          .LoadPointsFromFile SwApp.GetCurrentMacroPathFolder & "\a3.SldTab"
          Sub Ll2()
              Dim SwApp                   As SldWorks.SldWorks
              Dim SwModel                 As SldWorks.ModelDoc
              Dim swSelMgr                As SldWorks.SelectionMgr
              Dim swFeat                  As SldWorks.Feature
              Dim swTableFeatData         As SldWorks.TablePatternFeatureData
              Dim swRefPt                 As SldWorks.Vertex
              Dim swCoordSys              As SldWorks.Feature 'Object
              Dim vBasePt                 As Variant
              Dim vFace                   As Variant
              Dim vFeat                   As Variant
              Dim vPt                     As Variant
              Dim nPtType                 As Long
              Dim vRefPtParam             As Variant
              Dim bRet                    As Boolean
              Dim i                       As Long
              Set SwApp = Application.SldWorks
              Set SwModel = SwApp.ActiveDoc
              Set swSelMgr = SwModel.SelectionManager
              Set swFeat = swSelMgr.GetSelectedObject5(1)
              Set swTableFeatData = swFeat.GetDefinition
              ' Roll back to get the reference point
              bRet = swTableFeatData.AccessSelections(SwModel, Nothing): Debug.Assert bRet
              Set swRefPt = swTableFeatData.ReferencePoint
              Set swCoordSys = swTableFeatData.CoordinateSystem
              vBasePt = swTableFeatData.GetBasePoint
              vFace = swTableFeatData.PatternFaceArray
              vFeat = swTableFeatData.PatternFeatureArray
              vPt = swTableFeatData.PointArray
              If Not swRefPt Is Nothing Then
                  ' Is NULL if centroid used
                  vRefPtParam = swRefPt.GetPoint
                  Debug.Print "  RefPt                = (" & vRefPtParam(0) * 1000# & ", " & vRefPtParam(1) * 1000# & ", " & vRefPtParam(2) * 1000# & ") mm"
              Dim ii, Str, Arr()
                ReDim Arr(UBound(vPt))
              For ii = 0 To UBound(Arr)
                Arr(ii) = vPt(ii)
              Next ii
              With swTableFeatData
                 .PointArray = Arr
                 Debug.Print SwApp.GetCurrentMacroPathFolder & "\a3.SldTab"
              End With
              swTableFeatData.ReleaseSelectionAccess
          API Table Feature - DASSAULT: SOLIDWORKS 3D Design - Eng-Tips
          http://www.eng-tips.com/viewthread.cfm?qid=133453
              Daniel Andersson
              Will make you lose the changes... see Remarks for 2014 SolidWorks API Help - ReleaseSelectionAccess Method (ITablePatternFeatureData)
              Use this method to restore the rollback state if you did not modify the feature, or use IFeature::ModifyDefinition or IFeature::IModifyDefinition2 if you did modify the feature.
              Use 2014 SolidWorks API Help - ModifyDefinition Method (IFeature) instead of the ReleaseSelectionAccess method.
              Which means replace:
              with
              swFeat.ModifyDefinition swTableFeatData, SwModel, Nothing
              and it will work.
              You should also keep an eye on the file extensions since the API reference refers to file extension sldptab and not sldtab. However, this is not that critical as long as the format of the text rows is correct.
                  Yong Ning
                  Thanks your web like
                  The need for further study "ModifyDefinition" statement
                      Dim SwModel                 As SldWorks.ModelDoc2
                      Dim SwTabFeat As TablePatternFeatureData
                      Dim bRet                    As Boolean
                        Path = SwApp.GetCurrentMacroPathFolder
                        Debug.Print Path
                      Set SwTabFeat = swFeat.GetDefinition
                      With SwTabFeat
                        tmp = .AccessSelections(SwModel, Nothing)
                        .LoadPointsFromFile Path & "\aa.SldPTab"
                      End With
                      swFeat.ModifyDefinition SwTabFeat, SwModel, Nothing
                      Dim swApp                   As SldWorks.SldWorks
                      Dim swModel                 As SldWorks.ModelDoc2
                      Dim swSheetMetal            As SldWorks.SheetMetalFeatureData
                      Dim bRet                    As Boolean
                      Set swModel = swApp.ActiveDoc
                      Set swSheetMetal = swFeat.GetDefinition
                      Debug.Print "Feature = " & swFeat.Name
                      Debug.Print "  BendRadius = " & swSheetMetal.BendRadius * 1000# & " mm"
                      ' Rollback to change default bend radius
                      bRet = swSheetMetal.AccessSelections(swModel, Nothing): Debug.Assert bRet
                      ' Double the default bend radius value
                      swSheetMetal.BendRadius = 2# * swSheetMetal.BendRadius
                      ' Apply changes
                      bRet = swFeat.ModifyDefinition(swSheetMetal, swModel, Nothing): Debug.Assert bRet
