0 Replies Latest reply on Dec 9, 2014 5:50 PM by Richard Cook
    How to select points in a sketch then add relations to points in a 2nd sketch.
    Richard Cook
      Hi
      In this app, I first create a 3dSketch with points from a known source.
      I stored the persistant ID cordinates and sketch name in an indexed structure like.
      myPoints(n).Id0. .Id1 .skName... and some other info, when I create the points.
      I then create a 2nd 3dSketch dropping connector lines between some of those points.
      So as I create lines in the new sketch I would like to make the end points coincident to the points in the first sketch.
      So...I create a line from XYZ1 to XYZ2 .
      ...clear selections...
      And now how to best select the 2 points.
      What method should be used to select the startpoint (or endpoint) of the line just created?
      Do the line points have a persistent id or just the line has a persistent ID?
      What method to select the point from the first sketch using the persistent ID?
      now that the 2 points are selected just add the relation..
      move on to the end point and do the same.
      then the next line.
      RIchard
