I have an assembly made up of both parts and other assemblies. I have some customer properties defined in all the parts. Some of the parts are being purchased and some are being made. What is a quick way that I can display only those parts being made by a particular vendor?
Eric,
You could try using the Advance Select option. Click on the drop down arrow on the select icon at the top of the screen & Advance Select is at the bottom. You can make up rules for selection of parts & items within your assembly & save them if needed again.
Or you might be able to use the filter search at the top of the tree, although I think this is limited to content within the part title, description & I think tags as well but could be wrong on that.
