I need to get the length and width from the piece that I am working on so I was looking for bounding rectangle information. This is all free-form surface geometry so I don't have any dimensions associated with the length and width. I am trying to create a quick formula to grade up a size run of insoles for a boot. I am tired of doing it manually all the time. I would really like to automate the process. I would need the dimensions from the bounding rectangle to have a variable assigned to them in SW somewhere.
Chris
Chris -
I think, if you insert a Weldment Feature (Insert -> Weldments -> Weldment), then, in the Feature Tree, RMB "Cutlist" and click "Update". If you RMB "Cut List Item" under Cutlist, there's a "Create Bounding Box" menu selection. I don't use it much myself, so I'm not positive of all it's uses, but I think the Bounding Box automatically creates Configuration specific Properties that could be accessed for the info you're trying to compile.
Steve R.
