3 Replies Latest reply on Dec 19, 2014 8:04 PM by Subhra Maiti
    SelectByID2 doesn't work in VB.NET at all
    Charlie Fan
      Hi Guys, Below is the code of macro I used to select sketch:
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
      This code works perfectly in macro.
      However, I tried the same thing in VB.net:
          swApp = New SldWorks.SldWorks()
          Dim Part As Object
      And I compile the code in VS2013. When running, it however doesn't work and throw a "Type Mismatch error"
        • Re: SelectByID2 doesn't work in VB.NET at all
          Charlie Fan
          Can Any one kindly help find why it doesn't work?
          I have made a few other stand-alone exe with solidworks and they work fine.
          Thank you very much.
            Rajat Jain
            Charlie,
            Can you check the following code: -
                if not swApp is nothing then
                      Dim Part As SldWorks.ModelDoc2
                      If not Part is Nothing then
                          Dim swModelExtension as SldWorks.ModelDocExtension
                          swModelExtension = Part.Extension
                          If Not swModelExtension is nothing then
                              boolstatus = swModelExtension.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
                            swModelExtension = nothing
                      Part = Nothing
                Endif
                swApp = Nothing
            Hope it helps!!!
            Rajat Jain
