Hi All;
I am facing a truss automation problem.If you see the picture 1, you can find that I create a master sketch which will generate 4 parts.The variable dimensions are red underlined on picture 2.and the base plate is parallel to the top plane of the assembly.Everything works fine when I automate a single truss but it gives a problem when I create a bigger assembly (picture 4) using those input in picture 2. It creates the assembly like picture 4 but the bottom base plate creates a angle to the top plane as like picture 5. There is no error in the drive works panel,no error in assembly generation. If I try using master model and manually stretch it,it works fine. There is no angle.As soon as I apply driveworks to making a bigger assembly the same truss give an error.I tried several different ways of mating the assembly but the result is same.Is there any issue in my generation? How can I solve that?
