For a while (it might be since the update to SW2014 - SP5), I have this annoying problem:
After double-clicking a dimension, the cursor defaults to the dimension name, instead of the dimension value. So, when when I try to change a dimension from value 10 to 15, I accidentally change the dimension name to 15, not the value. Workaround is to press TAB once, or click the cursor in the right box.
I tried:
-Check with both old and newly created files
-Reset all settings (Tools-options-reset all)
-Delete Solidworks setting in the registry
-Restart computer
The above didn't help. I can't find a solution. Anyone..?
Thanks!
I don't see that behavior so please report this to your VAR and let them take care of the issue.
