6 Replies Latest reply on Jan 6, 2015 11:25 AM by Jared Conway
    Cannot find associated with this item - problem
    Jakub Hazmuka
      Hello i have problem with imported model. I want to observe the quantity of solar radiation hitting on the surfaces. (I imported model from the Autocad 2015 (.dwg). When the importing ends the bar appears to me:
      The model is now imported and it looks fine.
      Then i created the model for flow simulation with help of Wizard, I set Heat conduction in solids; Heat conduction in solids only, Radiation and solar radiation is checked too.
      (i want the observe only radiation)
      Then i use the;
      Flow simulation -> Tools -> check geometry
      When i use the check button, the report say me: Status:succesful, geometry is OK
      I want to put the "surface goal"
      But the error will show.
      Will anybody help me, how to solve it?
      I have not any openings in model; and no error in model (no čer2.JPGčer.JPG)
      i just tried these link, but it doesnt help:
      Cannot find the faces associated with this item.
