APAlan Phillipson01/12/2014
Hi and help please!
Please bear with me. I'm new to solidworks and am self teaching,  but an experienced engineer and lasercutter.
I have created a large number of parts and assemblies in Solidworks. These assemblies are a model which is to be constructed from interlocking laser cut mdf/plywood profiles. the MDF/ply is to be cut on a laser cutter.
I need to create a DXF/DWG file to drive the laser cutter. Each of my parts is a separate part file (which allows me to 3d model and assemble)
How will i create this file from Solidworks? I've not used drawings before in solidowrks so am a little uncertain as to how to do this, and how to set things like line colour that drives through cut or engrave commands for the laser cutter.
Also i am at a loss how to create an engrave profile in solidworks. In effect the engrave feature is a zero thickness 2D line which forms a path for the laser cutter. How can I show this on my 3d parts in assemblies. And how do i get tit to show up as a different colour in my dxf/dwg file (see above)
hope that makes sense...
Alan
As an example - attached is a jpeg image that shows the complexity of assembly and number of components i have.
