9 Replies Latest reply on Feb 4, 2019 11:01 AM by Sean Leahy
    Programmatically saving BOM to Excel
    Mike Campbell
      I've surfed the forum for solutions. Only one potentially fits my need if only I could get it to work. Note that the BOM does get created but does not get saved out. There are no errors, just no file.
      Option Explicit
      'Preconditions: Assembly file is active and includes components
      'Postconditions: A file is saved which contains BOM info
      Dim swApp           As SldWorks.SldWorks
      Dim swModel         As SldWorks.ModelDoc2
      Dim swBOMTable      As SldWorks.BomTableAnnotation
      Dim swTable         As SldWorks.TableAnnotation
      Dim swAnn           As SldWorks.Annotation
      Dim strBOMTemplate  As String
      Dim strOutputPath   As String
      strBOMTemplate = "D:\Users\204065774\Documents\SolidWorks\Mike's templates\standard BOM.sldbomtbt"
      Set swModel = swApp.ActiveDoc
      Set swBOMTable = swModel.Extension.InsertBomTable(strBOMTemplate, 0, 0, 3, "default") 'BOM is created in the assembly
      Set swTable = swBOMTable
      strOutputPath = "c:\" & "BOMTable_" & Left(swModel.GetTitle(), Len(swModel.GetTitle) - 7) & ".xls"
      Debug.Print strOutputPath
      swTable.SaveAsText strOutputPath, vbTab 'Nothing happens here. No errors, no file, nothing.
        • Re: Programmatically saving BOM to Excel
          Jason Kerns
          Have you tried saving to that location manually?
          I tried to save to my "C:\" location but do not have permission.
            Roland Schwarz
            Here's a macro that scans a BOM and copies it to the clipboard in a format that is Excel-friendly.
            BOM to Clipboard macro
              Mike Campbell
              Here's a working example of exporting the BOM from the assembly to Excel.
              Option Explicit
              'Preconditions: Assembly file is active and includes components.
              'Postconditions: An Excel file is saved which contains BOM info for a configuration named "default". _
              The file is saved in D:\SWIM_CACHE. Each time the macro is executed the new file overwrites the old one. _
              The file name follows the pattern "BOMTable_(assembly file name).xls"
              'Add Microsoft Excel to references
              Dim strBOMTemplate  As String 'Path and name of SolidWorks BOM template
              Dim strFilename     As String 'Path and name of Excel file (.xls)
              Dim strTemp         As String 'Path and name of text file (.txt)
              'The SolidWorks BOM template must reside in a location common to all users
              strBOMTemplate = "\\tnwp09662\Solidworks Options Files\Read Only\BOM Templates\BOM-standard.sldbomtbt"
              'BOM is created in the assembly for a configurations named "default"
              strFilename = "D:\SWIM_CACHE\" & "BOMTable_" & Left(swModel.GetTitle(), Len(swModel.GetTitle) - 7) & ".xls"
              strTemp = "C:\Temp\Temp.xls"
              'Save text file (.txt)
              swTable.SaveAsText strTemp, "" 'vbTab is default delimiter for text file (.txt)
              OpenExcelFile strTemp, strFilename 'Call sub
              'Postcondion: Text file (.txt) is saved as Excel file (.xls)
              Sub OpenExcelFile(Temp As String, Filename As String)
              Dim ExcelBOM As Excel.Workbook
              Set ExcelBOM = Workbooks.Open(Temp) 'Open .TXT file in Excel
              If DoesFileExist(Filename) = True Then 'Call function
                  Kill Filename 'If .XLS file already exists, delete it.
              ExcelBOM.SaveAs Filename, 39, , , , , , 2 'Save .TXT file as .XLS
              ExcelBOM.Close
              'Postcondition: File is determined to exist or not.
              Function DoesFileExist(Filename As String) As Boolean
              If Len(Dir$(Filename)) > 0 Then
                  DoesFileExist = True
                  Else: DoesFileExist = False
              End Function
                Paul Flores
                Thanks Mike, this mostly works for me, but I have a few problems.
                When I run this, I get an error message:
                     Compile error:
                     User-defined type not defined
                The following line is highlighted in yellow on the debugger
                And the following is highlighted in blue
                That said, the Temp.xls file is created and I can open it from the folder as long as I hit the Yes button on this pop-up message:
                The file you are trying to open, 'Temp.xls' is in a different format than specified by the file extension. Verify that the file is not corrupted and is from a trusted source before opening the file. Do you want to open the file now?
                Any ideas on what's going on here?
                Using Solidworks 2014 and Excel 2010.
                  Mike Campbell
                  Notice "Add Microsoft Excel to references". Did you do that?
                  1 person found this helpful
