PDF Macro with Revision Info
Question asked by Will Frost on Dec 2, 2014
Latest reply on Dec 2, 2014 by Will Frost
Hi I'm using the below code to try and generate a pdf from a drawing that includes revision information.  The code currently pulls this from the "custom properties" in the drawings properties, but need to change this so it's pulled from the custom properties of the Part file, can anyone advise how this is done?
Code:
Dim SwApp As SldWorks.SldWorks
Dim Model As SldWorks.ModelDoc2
Dim MyPath, ModName, NewName As String
Dim MB As Boolean
Dim Errs As Long
Dim Warnings As Long
Dim reesolvedValOut As String
Dim revTag As String
Dim swConfigMgr         As SldWorks.ConfigurationManager
Dim swConfig            As SldWorks.Configuration
Dim swCustPropMgr       As SldWorks.CustomPropertyManager
  Set SwApp = Application.SldWorks
' This ensures that there are files loaded in SolidWorks
  Set Model = SwApp.ActiveDoc
  Set swConfigMgr = Model.ConfigurationManager
  Set swConfig = swConfigMgr.ActiveConfiguration
  If Model Is Nothing Then
      MB = MsgBox("No drawing loaded!", vbCritical)
      Exit Sub
    End
'Get Revision Tag
  Set swCustPropMgr = Model.Extension.CustomPropertyManager("")
  swCustPropMgr.Get2 "Revision", revTag, reesolvedValOut
' Admonish user if attempted to run macro on part or assy file
  If Model.GetType <> 3 Then
      SwApp.SendMsgToUser "Current document is not a drawing."
      End
' Use one of the three following options for PDF save location
' Comment out the options with are not used.
' Option 1: Use the current directory
'  MyPath = CurDir
' Option 2: Specify the directory you want to use '  MyPath = "C:\PDF"
' Option 3: Use the drawing folder
  MyPath = Left(Model.GetPathName, InStrRev(Model.GetPathName, "\") - 1)
' Status
  ModName = Left(Model.GetTitle, InStrRev(Model.GetTitle, " Sheet") - 3)
  NewName = ModName & " REV " & revTag & ".pdf"
  MsgBox "Save file:" & Chr(13) & NewName & Chr(13) & Chr(13) & "To location:" & Chr(13) & MyPath & Chr(13) & Chr(13) & "No notification will occur for success PDF creation."
' PDF Creation
  MB = Model.SaveAs4(MyPath & "\" & NewName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Errs, Warnings)
' Warnings to user on Error
'  MsgBox "Errors: " & Errs & vbCrLf & "Warnings: " & Warnings
  If Warnings <> 0 Then
     MsgBox "There were warnings.  PDF creation may have failed. Verify " & Chr(13) & "results and check possible causes.", vbExclamation
     Else
  If MB = False Then
     MsgBox "PDF creation has failed!  Check save location, available" & Chr(13) & "disk space or other possible causes.", vbCritical
     Else
'Clear immediate values
  Set Model = Nothing
  Set MyPath = Nothing
Many thanks for the help!
