I am working with the ISO spur gears for a project, where different sized gears fit together. I would like to know if it is possible to calculate the number of teeth for a gear, when i know the outside diameter of the gears and the distance between their axes?
Magnus, you don't have enough information to determine the answer to your question. There are many different solutions to your question. What gear ratio to you need? Do you want a 2 to 1 or a 5 to 1, what RPM do you want to at the final drive. So many things factor in for the gears.
Bill
