Hello there,
I have an assembly module as the one shown on the picture. I need to have the same one, but mirrored to the pointed wall. Is there a way to mirror all at once and leave only the mirrored module? There are mainly sheet metal parts and pipes.
In part level it is easy to do it , by select the plane then , insert menu , mirror part. but unfortunately this tool is not in the assembly so you can do the following, insert this assembly as a sub-assembly in a new assembly , then select Mirror Components command, then select your sub-assembly , Make sure you selected create opposite hand version & break the link to original part. Then delete your original assembly.
