Hi there,
I am using Solidworks 2014-2015 student version and it stops working when I tried to insert a cut plot diagram into my flow simulation.
I thought this problem was caused by model complexity but it is obvious not. I tried to simulate flow past a sphere with lowest mesh setting and two goals only but my Solidworks stop working when I click 'insert' cut plot (not even set up cut plot).
I attached my model file(which is just a sphere) and my system data. It will be appreciated if somebody can help me solve this out as I really need this function.
Video Cards: GTX 765M (with latest 344.75 driver version)
i7-4900MQ CPU@2.80 GHz
16 Gb RAM
Windows 8.1 Pro
Cheers.
same suggestion as here
Simulation Crashes when viewing cut plot
enable software opengl with no solidworks files open and see if it helps. disable switchable graphics. test on a simple tube.
