Setting custom property fails with swCustomInfoNumber and number with decimals
Question asked by Bill Florac on Nov 30, 2014
Latest reply on Dec 1, 2014 by Bill Florac
I can't seem, to add a custom property using the Add3() function if the type is number and the number has a decimal in it.  The following code works if the number is "123" but does not work if the number is "123.456". As a work around, it does seem to work if I add it as an integer "0" and then use the set2() function to modify it.
    Dim swModel As ModelDoc2
    Dim cusPropMgr As CustomPropertyManager
    Dim ModelExt As ModelDocExtension
    Dim lRetVal As Integer
    Public Sub main()
        swModel = swApp.ActiveDoc
        ModelExt = swModel.Extension
        cusPropMgr = ModelExt.CustomPropertyManager("") '
        ' This fails with swCustomInfoAddResult_GenericFail
        lRetVal = cusPropMgr.Add3("ANUMBER", swCustomInfoType_e.swCustomInfoNumber, "123.456", swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd)
        ' This seems to work if I use "0" as the value above first
        ' lRetVal = cusPropMgr.Set2("ANUMBER", "123.100000")
Am I doing something wrong here?
