I am a little bit crazy finding a solution for:
- I use the Edrawings ActiveX control to open files on a MS Access2010 form, that is running perfectly.
- Now i want that the user introduce the name of the file, and using VBA for Access the program find the file and open it. That is working, but......
What i need is that the program open the file on any folder, because the user don´t know where is located the file, so the VBA must find all over the disk to find the file.
Any help will be very much appreciated.
Thank you in advance.
Thank you Daniel, i found an alternative routine.
