How to use sentence  of InsertTableDrivenPattern
Question asked by Yong Ning on Nov 27, 2014
2010 SolidWorks API Help - InsertTableDrivenPattern Method (IFeatureManager)
http://help.solidworks.com/2010/english/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.ifeaturemanager~inserttabledrivenpattern.htmlTable-driven+Pattern.jpg
value = instance.InsertTableDrivenPattern(FileName, PointVar, UseCentrod, GeomPatt)
How to write FileName???????
FileName = "E:\MyWorkSummary\BESmodel\浮头换热器\Tube Bundle\" & "1.Txt"
PointVar? → How to Set  Point varay
PointVar → How to set Point
UseCentrod → True ? or False?
GeomPatt → True? or False?
Private Sub ss()
   Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
      Set SwApp = Application.SldWorks
      Set SwModel = SwApp.ActiveDoc
   Dim SwFeatMgr As FeatureManager, Tab1 As TablePatternFeatureData
      Set SwFeatMgr = SwModel.FeatureManager
   Dim FileName, Pt(1) As Double
      Debug.Print SwModel.GetPathName
      Path = "E:\MyWorkSummary\BESmodel\浮头换热器\Tube Bundle\"
      FileName = Path & "1.Txt"
      SwFeatMgr.InsertTableDrivenPattern FileName, Pt, True, True
      Stop
2013 SolidWorks API Help - Get Points of Repeating Elements in Table-driven Pattern (VBA)
http://help.solidworks.com/2013/English/api/sldworksapi/Get_Points_of_Repeating_Elements_in_Table-driven_Pattern_Example_VB.htm
Function InsTabDrivenPattern(SwModel As ModelDoc2, FileName, FeatName, CoordName, BodyArr)
   Dim SwFeat As Feature, SwFeatMgr As FeatureManager
   With SwModel.Extension
     .SelectByID2 CoordName, "COORDSYS", 0, 0, 0, False, 16, Nothing, 0
     For ii = 0 To UBound(BodyArr)
       .SelectByID2 BodyArr(ii), "BODYFEATURE", 0, 0, 0, True, 4, Nothing, 0
     Next ii
   End With
   Set SwFeat = SwFeatMgr.InsertTableDrivenPattern(FileName, Nothing, True, True)
   SwFeat.Name = FeatName
   'SwFeat.Select True
   'SwModel.EditSuppress2
End Function
Private Sub del20150205()
   Dim T: T = Timer
   Dim Xls As Excel.Application, Rng As Range
      Set Xls = GetObject(, "Excel.Application")
      Set Rng = Xls.Selection
   Dim Rng1 As Range, Rng2 As Range, FileName
      Set Rng1 = Rng.Areas(1)
      Set Rng2 = Rng.Areas(2)
   Dim Path, BodyArr: BodyArr = Array("Hole")
      Path = SwModel.GetPathName
      Path = Left(Path, InStrRev(Path, "\")) & "布管\"
      For ii = 1 To Rng.Rows.Count
         SwModel.ShowConfiguration2 Rng1(ii, 1)
         FileName = Path & Rng2(ii, 1)
         InsTabDrivenPattern SwModel, FileName, Rng1(ii, 1), "CoordSys", BodyArr
         Debug.Print Rng1(ii, 1),
         printTiming T
         UnSuppressConfigEquiFeat SwModel
         'Stop
      Next ii
      printTiming T
      SwModel.SaveAs Path & "del.SldPrt"
      SwApp.CloseDoc SwModel.GetTitle
      printTiming T
     SwApp.ExitApp
      Timing T
Private Sub replTablePatternFeatName()
   Dim ConfArr, Kk As Integer
      Kk = 1
      ConfArr = SwModel.GetConfigurationNames
      'For ii = 0 To UBound(ConfArr)
         SwModel.ShowConfiguration ConfArr(ii)
         Set SwFeat = SwModel.FirstFeature
         Do While Not SwFeat Is Nothing
            If SwFeat.GetTypeName = "TablePattern" Then
               SwFeat.Name = Trim(Replace(SwFeat.Name, "FixTubeSheet", ""))
               Debug.Print SwFeat.Name
            Set SwFeat = SwFeat.GetNextFeature
         Loop
         Stop
      'Next ii
Private Sub TablePatternSuppress()
      Kk = 1
               SwFeat.Select True
         Loop
      Next ii
Private Sub TablePatternUnSuppress()
   Dim T: T = Timer
      Kk = 1
      'For ii = 0 To UBound(ConfArr) - 6
      For ii = UBound(ConfArr) - 5 To UBound(ConfArr)
            If SwFeat.Name = ConfArr(ii) Then
               Debug.Print Timer / 60
               SwFeat.Select True
               SwModel.EditUnsuppress
               'Stop
               Exit Do
         Loop
      Next ii
   Timing T
Private Sub unSuppressFeat()
   Dim ConfArr, SwConf As Configuration
     With SwModel
        ConfArr = .GetConfigurationNames
           Set SwFeat = .FeatureByName("Coordinate System1")
           SwFeat.Select True
           Set SwFeat = .FeatureByName("Delta")
           SwFeat.Select True
           .EditUnsuppress
        Next ii
     End With
