MPMike Piller26/11/2014
Trim Surface
You can use a surface, plane, or sketch as a trim tool to trim intersecting surfaces. You can also use a surface in conjunction with additional surfaces, as mutual trim tools. Trim surface includes the following options:
To trim a surface:
- Create two or more surfaces that intersect at one or more points, or create a surface that intersects with a plane or has a sketch on its face.
- Click Trim Surface
on the Surfaces toolbar, or click .
- In the PropertyManager, under Trim Type, select a type:
- Standard. Trims surfaces using surfaces, sketch entities, curves, planes, and so on.
- Mutual. Trims multiples surfaces using the surfaces themselves.
- Under Selections, choose from these options:
- Trim tool
(available with Standard selected under Trim Type). Select a surface, sketch entity, curve, or plane in the graphics area as the tool that trims other surfaces.
- Surfaces
(available with Mutual selected under Trim Type). Select multiple surfaces in the graphics area for Trimming Surfaces to use to trim themselves.
- Select a trim action:
- Keep selections. Retains the surfaces listed under Pieces to Keep
. Intersecting surfaces not listed under Pieces to Keep are discarded.
- Remove selections. Discard the surfaces listed under Pieces to Remove
. Intersecting surfaces not listed under Pieces to Remove are retained.
- Select surfaces in Pieces to Keep
or in Pieces to Remove
, based on the trim action.
- Trim tool
- Under Surface Split Options, select an item:
- Natural. Forces the boundary edges to follow the shape of the surface.
- Linear. Forces the boundary edges to follow a linear direction from the trim point.
- Split all. Display all splits in the surface.
- Click
Example Using Standard Trim Type | ||
Sketch used for Trim tool | Pieces to Keep | Trimmed surface |
Example Using Mutual Trim Type | ||
Two intersecting surfaces | Surfaces selected for Pieces to Keep | Trimmed surface |
Parent topic
I've been trying to trim surfaces using the steps above. They do not work!!! I keep getting an error that asks for a surface to trim. It is set om "mutual" so the surfaces are supposed to trim each other. THEY DON"T!! How do I get this to work???
