Is it possible to change the thickness of a sheet metal part via API?
I have found in the api help the code to change the bend radius (see: 2014 SolidWorks API Help - Change Bend Radius of Sheet Metal Part Example (VBA) )
and added a few lines to change the thickness. But the thickness does not change.
What do I do wrong?
Here is the code i found and changed a little:
' Preconditions:
' (1) Part document containing sheet metal part is open.
' (2) Sheet-Metal feature is selected.
' Postconditions: Default bend radius value is doubled.
Option Explicit
Dim swFeat As SldWorks.Feature
Dim swSheetMetal As SldWorks.SheetMetalFeatureData
Dim bRet As Boolean
Set swModel = swApp.ActiveDoc
Set swFeat = swSelMgr.GetSelectedObject5(1)
Set swSheetMetal = swFeat.GetDefinition
MsgBox swSheetMetal.Thickness
Debug.Print "Feature = " & swFeat.Name
Debug.Print " BendRadius = " & swSheetMetal.BendRadius * 1000# & " mm"
' Rollback to change default bend radius
bRet = swSheetMetal.AccessSelections(swModel, Nothing): Debug.Assert bRet
swSheetMetal.BendRadius = 2# * swSheetMetal.BendRadius
swSheetMetal.Thickness = 2
' Apply changes
bRet = swFeat.ModifyDefinition(swSheetMetal, swModel, Nothing): Debug.Assert bRet
Thanks in advance,
Henk Kemper
