I would like to create lifting lug using an "IF mass > 12000 THEN dim = 12 ELSE dim =10. If I use SW-Mass I get a circular reference. As the dimension changes so does the mass. Using a sensor and a selection set would eliminate this by removing the lugs from the equation.
