I'm trying to build new wheel pants for our Bonneville Streamliner.
SurfaceCut5 seems to get suppressed when I Unsuppress the Flat-pattern18 feature.
I need the dxf of the wheel well half for the waterjetting.
Any ideas?
Any ideas?
1. Delete everythig tha lies under Surface-Offset1 except Sketch7
2. Make Surface-Offset1 visible and hide rest.
3. Adjust diameter in Sketch7 to show tthe outer diameter of wheel well.
4. Make extruded surface from Sketch7 up to Surface-Offset1.
5. Thicken result. Choose correct direction.
6. Choose edge shown on screeshot and use Insert Bend. Hit OK.
7. Hit Flatten........
Robert, Krzysztof,
Unless there is a reason that's not apparent to me, you can skip converting to sheet metal and just use a Base Flange to create the piece as sheet in one step. See my example in the post below.
I find sheet metal parts almost always work best if you can make them as sheet metal from the start. I save thickening surfaces, shelling solids, etc. with convert to sheet metal for situations that really require it.
Robert,
The surface cut is apparently too complicated for sheet metal flattening, not a normal cut. I changed the swept flange to a base-flange extruded up to the surface, and switched from using Bend Allowance to K-factor and the part flattens nicely. See if this will work for you. On a radius this big the K-factor value is probably OK at .5 but you might want to tweak it if you have necessary forming info.
Hi.
Try to do this as a surface first. Extrude surface and trim to get shape. Then thicken it and convert to sheet metal by using insert bends option.
