Good day from DownUnder:-)
I am designing new mudguard for new utes and but I have come across to one edge that needs to have a smooth transition from 90 deg down to 45 deg.
( see photos bellow ) and MY PART SW ATTACHED.
I have done it using Surface Loft Feature ( pretty dodgy :but I need to get this done different way so it will also be a part of Flat Pattern.
At this stage, the mudguard looks ok but its only cosmetic. The Flat-Pattern is all wrong.
I am not sure how I could possibly do it. Can you help guys? Thank you so much :-)
Hi Fred, I don't think there is any way to make this a unfoldable sheet metal feature. I did find way to make the model look real good using a solid loft. At least it is satisfying to look at. You'll have to suppress the features for the drawing though and go in and manually clean it up as best as you can. Don't underestimate the power of a well written note to explain on the drawing.
First make the part as you and others already started.
Second go in and trim away the bit of metal so as to expose the 90 and 45 degree bends completely.
Then open up new sketches on each of the four faces and convert them to sketches. Make a loft from the two long straight faces using "Normal to Face" Start and End constraints.
For the final Loft use the edges of the curvy loft and the base flange as guide curves to keep everything in line and looking good.
Ah lookin' good!
