5 Replies Latest reply on Nov 25, 2014 9:12 PM by Velibor Marjanovic
    Getting physical dimension value out of particular sketch?
    Velibor Marjanovic
      at the moment I am stuck with trivial issue (it should be, unless I don't get this at all) in regards to passing dimension out of sketch:
      Dim swPart as IPartDoc
      Dim featureOfPart as IFeature = Nothing
      Dim sketchWidth As IDimension = Nothing
      Dim dblSketchWidth as Double = 0
      swPart = swApp.ActiveDoc
      featureOfPart = swPart.FeatureByName("Something")
      sketchWidth = featureOfPart.IParameter("Width@SomethingSketch@SomethingPart.sldprt")
      dblSketchWidth = sketchWidth.IGetSystemValue3(swInConfigurationOpts_e.swThisConfiguration, 1, Nothing)
      MsgBox (dblSketchWidth)
      Getting an error: "Use the "new" keyword to create object instance.".
      Tried other functions (dimension.value, IGetValue3) which returns double value from dimension but with same issue and message.
      IGetSystemValue3 should return double value of the length. Please let me know what I am missing here. I tried to use SelectionByID, but that function uses x, y, z coordinates and what I need it is length of line, not its location in space. BTW using SW2014 with Visual Basic.Net as macro language.
      Thanks.
        • Re: Getting physical dimension value out of particular sketch?
          Daniel Andersson
          Have you tried  to change
          To
          sketchWidth = featureOfPart.IParameter("Width")
          It might also be that your "Something" feature is not the actual sketch feature.
          See this post as reference:
          https://forum.solidworks.com/thread/62821?forceNoRedirect=true
          And I'm not sure but the "1" in
          Might be set to nothing since you are not specifing any specific configuration (swSpecifyConfiguration).
          Could you please state on which line you get the error if my suggestions do not help.
              Velibor Marjanovic
              Ooops clicked previously  on wrong one...
              Hi, first of all thanks for helping.
              I did change upper suggestion (in regards to "Width"), and changed function name to sketchWidth.GetValue2("Default"), so I can avoid numbering configurations (decrease number of potential problems) and again getting same error. Debugger stops actually right on that line: dblSketchWidth=sketchWidth.GetValue2("Default"). BTW default is only configuration available.
              Really not quite sure what is issue here???
                  Daniel Andersson
                  GetValue2 is obsolete and you should stick with GetSystemValue3. Go for GetSystemValue3 and you will have different input and returns. Noticed that you tried to used IGetSystemValue3. I would follow the example below, taken from
                  http://help.solidworks.com/2014/english/api/sldworksapi/Get_Depth_of_Extrusion_Example_VBNET.htm
                  E.g.....
                          Dim swModel As ModelDoc2
                          Dim swDim As Dimension
                          Dim vConfigNames As Object
                          Dim vValue As Object
                          swModel = swApp.ActiveDoc
                          swDim = swModel.Parameter("D1@Boss-Extrude1") 'Would be Width@SomeSketch in your case.
                          Debug.Assert(Not swDim Is Nothing)
                          Debug.Print("File = " & swModel.GetPathName)
                          Debug.Print("  FullName     = " & swDim.FullName)
                          Debug.Print("  Name         = " & swDim.Name)
                          vConfigNames = swModel.GetConfigurationNames
                          vValue = swDim.GetSystemValue3(swInConfigurationOpts_e.swThisConfiguration, (vConfigNames))
                          Debug.Print("  SystemValue  = " & vValue(0) * 1000.0# & & "" & "mm")
                      Velibor Marjanovic
                      Hello Daniel,
                      thanks for the solution. Finally the issue is resolved, but for my overall understanding, I don't get it yet why it did not work out with:
                      swFeature = swPart.FeatureByName("Blahblah")
                      swDim = swFeature.IParameter("Something@SomethingElse")
                      dblValue = swDim.IGetSystemValue3(thisConfiguration, vConfigName)
                      Technicaly all parameters given are correct and should coincide with by function required return value (especially dblValue line as returned value should be the number).
                      Best regards,
                  Velibor Marjanovic
                  Hi, first of all thatnks for helping.
