I AM STARTING A PART WITH MULTIPLE GLOBAL VARIABLES. 2 OF THESE VARIABLES ARE SHOWING UP WITH YELLOW TRIANGLE ICONS (WARNINGS) HOWEVER IT DOESN'T TELL ME WHAT IS WRONG. THE ARE NOT NAMED THE SAME NOR DO THE EQUAL EACH OTHER. THEY ARE NOT LINKED TO ANYTHING OR USED IN ANY EQUATIONS. I DO NOT GET ANY REBUILD ERRORS, BUT I CANNOT GET THE ICONS TO GO AWAY.
UPDATE: IT SEEMS IT HAS TO DO WITH MY COMMENTS..... WHEN I DELETE THE COMMENTS THE ERROR DISAPPEARS.
PINION MINIMUM TOOTH THICKNESS (SPLINES)
I HAVE OTHER COMMENTS THAT ARE SIMILAR:
ALL CAPS
SPLINES IN PARENTHESES
It seems, that the issue is with Comment. Please try to add them in the " " sign. Warning dissapears. I can't tell you why SW shows this warnings.
Kind regards.
