I am trying to recreate the sketch in SolidWorks, I used to make in Inventor.
http://screencast.com/t/CBS4qcvDo
As you could see from video the last Vertical Relation makes this sketch over defined.
I do not see the apparent reason why the last Vertical Relation of the block should make this sketch overdefined.
If I would delete all slots, this sketch will accept the vertical relation of this block, but there are no any
ties between those square holes and slots, except probably the general quatity of Relations.
The sketch made in Inventor has even more coincident and vertical/horizontal relations (constraints) and stays fine.
Square holes and slots are also blocks.
Please advise possible reasons of such SolidWorks behavior or what I did wrong?
You are over defining your sketch. is there more to the video?
